Autoworld
Autoworld.com.my
Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> Starter Problem, Just had my starter serviced
neonlee
post May 3 2012, 07:21 PM
Post #1
Group: Members
Bro Razpower had tested drive my rex during last tt and he complaint to me why my car so hard to start .
It was caused byu started bearing worn off , i had serviced my starter today with replace bearing and carbon brush now.. my started sound very fine and start up is very easy.
Go to the top of the page
+Quote Post
r3xt0n
post May 3 2012, 09:55 PM
Post #2
Group: Members
QUOTE (neonlee @ May 3 2012, 07:21 PM) *
Do you feel the car shake a bit when starting before servicing your Starter? Shot any photo if can DIY servicing the starter?
+Quote Post
neonlee
post May 4 2012, 10:40 AM
Post #3
Group: Members
QUOTE (r3xt0n @ May 3 2012, 09:55 PM) *
No vibration , just hard starting , no photo.. sent to wireman to do the job..smile.gif
+Quote Post
tsleong67
post May 4 2012, 12:33 PM
Post #4
Group: Members
QUOTE (neonlee @ May 4 2012, 10:40 AM) *
If there is vibration during starting, the engine mounting is broken and need to be replace.
+Quote Post
r3xt0n
post May 4 2012, 12:51 PM
Post #5
Group: Members
QUOTE (tsleong67 @ May 4 2012, 12:33 PM) *
Nope, not the kind of vibration that due to engine mounting. Both my engine and transmission mounting is replaced new. It is like the kind of shake when you piss. hahahahah
+Quote Post
rex4585
post May 4 2012, 09:24 PM
Post #6
Group: Members
In the old days when my old diesel cars has difficulty starting in that the starter turns slowly,
I will send it for a service of the starter motor. Can really feel the difference. My old Rex had the starter serviced when I first bought it as it was lazy. Till now still very willing to turn fast.
+Quote Post
kenny4744
post May 11 2012, 02:24 AM
Post #7
Group: Members
hi bro
encounter a problem, anyone can help me solve
if i leave my rex unattended for a few days and i start the car the engine will die after
about 30second after starting, seem like the fuel is not going into the engine.
but after restarting again (sometimes it take 2 to 3 cranks to start the car )
it get back to normal
any one hv solution for this problem. it happens after i ask ah seng to wash my fuel line (from tank to diesel filter)
and change my diesel filter and prim pump
+Quote Post
tsleong67
post May 11 2012, 08:16 AM
Post #8
Group: Members
QUOTE (kenny4744 @ May 11 2012, 02:24 AM) *
hi bro
I think there is leakage on the check valve inside the prime pump. Fuel slowly leak back to the fuel tank and cause some air to be trap in the fuel line. You can try to prime the pump before starting to check if the engine will stop after 30second. Also check all fuel connection to made sure it is tight.
+Quote Post
kenny4744
post May 11 2012, 11:31 AM
Post #9
Group: Members
Thank for the solution.
How can i know if the fuel pipe is leaking. Is the hose from Tank to Filter High pressure or Low pressure.
+Quote Post
kenny4744
post Jun 2 2012, 03:19 AM
Post #10
Group: Members
QUOTE (kenny4744 @ May 11 2012, 11:31 AM) *
Hi All Bros
After replacing my warned out Priming Pump everything is back to normal.
Look out for wear and tear of the priming pump. Maybe we should press it one in a while. For mine I only notice that my pump is crack when i change my filter. It was too late. I have to bypass the primping pump using a fuel hose due to part inability from PG.
+Quote Post
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 31st March 2015 - 07:17 PM
